konstantinkoll
Running installer package twice
Dear AI-Team,
when running our installers on a blank machine, the software gets installed as it should. When running the very same installer (same version, GUIDs etc.) a second time, the "repair modify delete" dialog gets displayed. It is of no use in our case, as there are no optional features. Is there a way to bypass this dialog, maybe disable the "change" option?
Btw., the dialogs that appear afterwards, before changing or removing, don't seem to be customizable.
Thanks for your help,
Konstantin
Re: Running installer package twice
Hi Konstantin,
You can take a look on the Disable Modify does not work thread which debates a similar problem.
I'm afraid I don't fully understand this. Can you give us more details about this scenario (maybe exemplify)?
konstantinkoll
Ok, I get into the maintenance dialog, and choose either "Repair" or "Remove". Then a dialog apperas, similar to VerifyReadyDlg. Unfortunately, these dialogs do not seem to be the same, and does not appear in the Dialog editor - hence, it is messed up design-wise.
konstantinkoll
Hi Konstantin,
Those dialogs can be found in the Dialogs page under the "MaintenanceTypeDlg -> InstallMode = "Repair"" or "MaintenanceTypeDlg -> InstallMode = "Remove"" as you can see in the attached image.
Please keep in mind that our "Dialogs Editor" feature is available only in an " Enterprise" or higher project type.
konstantinkoll
Got them, thank you so much! :)
You're welcome. Glad to help.
