McKool
Problems with Dialog "SetupTypeDlg"
AI Version: 11.1
OS: Windows 8.1 (64-Bit)
Hello Forum,
I'm experiencing an annoying behavior when selecting if a feature should be installed or not. I have a main Feature, F, with two sub-features, A and B. These sub-features have at the same time their owns sub-features, F-A-1 and F-B-1 (3 levels feature).
Here a brief explanation about the configuration:
  • The hierarchy looks like:
    F
    ____A
    ________F-A-1
    ____B
    ________F-B-1
  • The Top-Parent feature (F) is configured to not be installed.
  • The Features A, B, F-A-1, and F-B-1 are configure as "Use Parent Feature Installation Settings"
The problem is with the last one (F-B-1)... When I select to install the Sub-Feature B, the Feature F-B-1 remains as "will not be installed". With A and F-A-1 it works as expected. It seems to be a Problem only with the last item of the hierarchy. Can you tell if this is a bug and/or if there is a workaround for this?
Thanks in Adavance!
Btw, here a pair of Pictures (F="Extended PnP Drivers", A ="Virtual PCAN-Gateway", B = "PCAN-USB Pro LIN"):
a) This is the initial state of the selection window:
Initial state
Initial state
b) This is the result of selecting to install the Feature F (Extended PnP Drivers):
After install all state
c) And this is the result of selecting to install only the Feature B (PCAN-USB Pro LIN):
Install the last sub-Item
Re: Problems with Dialog "SetupTypeDlg"
I'm afraid that this is a Windows Installer issue where the "Use parent feature installation settings" option is not applied correctly. However, if the "Entire feature will be installed" option is used to select a feature, the sub-features of that feature will be also selected.
McKool
OK, if they stay selected, then I'll just hide the sublevels.
thanks for the help and the quick answer.
Keneth
You're welcome Keneth. Glad to help.
Just let us know anytime you have a question.
