jdorninger
Windows Feature installer .NET 3.5 as a preinstall
Currently trying to install .NET 3.5 as a preinstall through Windows Feature bundle installer.
I need the .NET 3.5 for a programm I need to run after installing the main setup.
On windows 8.1/2012 the feature is not installed.
On the other windows version the pre-install works.
What am I doing wrong?
Br,
Jan
Re: Windows Feature installer .NET 3.5 as a preinstall
Hello Jan,
Indeed, if the target computer operating system is above Windows 8, then you can add the .Net Framework as a windows feature bundle to your installation package using the [New Windows Feature bundle] toolbar button and select it from our predefined Windows Features list.
You need to add the “.Net Framework” as a Windows Feature because you cannot install it by running its setup package (e.g. using a pre-install prerequisite). If you run its setup package you will be prompted with a warning which will require to install .NET Framework 3.5 as feature on demand.
This is the default behavior on Windows 8.
Let us know if that helped.
jdorninger
Thx for the answer.
I have done that, but the windows feature is not installed before the main installation.
That is resulting in following error during comit phase executing my .net 2.0 file
Br,
Jan
Hello Jan,
Please take a look on our Windows Features not working? forum thread which debates this subject.
jdorninger
The post was very usefull, but I went a different route
I used
  <startup useLegacyV2RuntimeActivationPolicy="true">
     <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/>
     <supportedRuntime version="v2.0.50727"/>
   </startup>
in my apps config and now it starts on computers which have either 2.0 or 4.0 installed.
The app is developed against .net 2.0
Br,
Jan
