esullivan81
Looking for best way
We have some software that requires several MSIs to be installed. We are having issues installing this in SCCM, I am hoping to combine everything in one to make it easier on SCCM.
The MSIs have files and folders it requires they are not just one file. The folder structure is attached in a picture.
I tried to create an MSI, that copies all that to a folder, then runs a BAT file to run the MSIs, however it was failing (I am assuming because two MSIs can run at the same time?)
I was reading up on chaining and prereqs, but it was lost on me. Anyone have a best way to do this? Step by step would be nice, as I am new to this software.
Thanks for any help.
esullivan81
Re: Looking for best way
Is there a way to add all the files into the MSI, extract everything to a temp directory, run the extracted MSIs one at a time then delete everything?
esullivan81
Right or wrong I made headway.
I added it all as prereqs, the ONLY issue is is continues to install the project I create to create the prereqs.
Anyway to stop it from finishing?
esullivan81
I was able to set it not to register with add\remove and set everything to silent and no ui. Working like a champ!
That is exactly what our suite installation tutorial does. Glad to hear you could find the solution all by your self.
