MarwaAhmad
exit code 536805277
I've AI 11.1: when i run AI from visual build pro and run the visual build pro from an asp.net project i got this error code regarding the AI: exit code 536805277.
note:
i could run the advanced installer successfully, but when i did the previous mentioned procedure it failed.
so, do you have any idea why this error code arise?
Marwa
Re: exit code 536805277
Hello Marwa,
Here's the exited with code 536805277 forum thread which debates this error.
MarwaAhmad
Thanks Dan, the issue was because the license was expired when i renewed it works; that's why the build wasn't run.
Also, i used the advint.exe in the commandline to rebuild and i'm just getting no error message, and when i used advancedinstaller.com it showed me the error message as well.
Marwa
You're welcome Marwa,
I'm glad you got this working. If there is anything else I can help you with, please let me know.
