McKool
Resulting "Setup exe file" is too big
Project Info:
AI Version: 11.1
Project-type: "Mixed 32/64-bit matching the platform"
Translations: English, German. Option: Create only a multilingual package.
Media: Exe setup with all resources inside
Hello Forum,
maybe this is just something that I am misunderstanding, but it seems for me as some files are being packed twice. I have a project which installs principally several merge modules, (MMs). Some of them are for 32-bits and others for 64-bits. Since my project is a mixed 32/64 project, AI creates two MSIs (one for each platform). My understanding is that it includes in each just the platform-matching MMs.
Now the problem: the resulting exe is twice bigger than it should. Compiling the project again with "Media" set to "Exe setup with resources next to it" shows that all MMs are also packed within the exe. Why? they are already included in each Msi file. I can see that the size of each Msi is more or less the expected size (according with the amount of MMs), but all MMs are packed again within the exe and they are also linked from each msi.
Exe - Resources.JPG (41.56 KiB) Viewed 6253 times
I would expect that they are either "packed inside of the Msi only", or that they are "outside and linked, but not inside the msi". Is this a bug or a misconfiguration in my project file?
Keneth
Re: Resulting "Setup exe file" is too big
Hi Keneth,
I tested your scenario and, indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
McKool
Hello Eusebiu,
can you tell me if there is any tentative Date for fixing this? My Setup is intended to be downloaded, and to be part of other installs. The size of the setup file is getting critical for me.
I will appreciate any information about this,
Keneth.
Hello Keneth,
I'm afraid I cannot give you an ETA for now. However, if you are interested you can send us an e-mail regarding this to support at advancedinstaller dot com and we'll provide you a RC of Advanced Installer including a fix for this issue. Also, most probably a fix for this issue will be included in 11.3 version of Advanced Installer. We will notify you when the fix will be officially available.
McKool
Thanks Daniel,
It would be nice to test with a RC candidate in the meantime, so that I can also have a RC of my setup ready. I will send an Email to Support.
Thank you.
This was fixed in version 11.3 of Advanced Installer released on June 17th, 2014.
