MarwaAhmad
Reset a sync. folder using AdvancedInstaller.com command
I have an advanced installer project which its Application Folder(in Files and Folders tab) is synchronized with a certain folder.
Now, I want to change that synchronized folder with another one using the command line (as shown in the attached figure.)
This is the old sync. folder.
C:\autobuild\programfiles\updatespublisher\test
and I want to pass a new sync. folder (using the command line) which is:
D:\programfiles\appfiles
The command I used to do this is:
AdvancedInstaller.com /edit C:\autobuild\programfiles\Installer.aip /ResetSync D:\programfiles\appfiles
But this didn't work, i got the following error:
Folder not found: D:\programfiles\appfiles.
Although that path i.e. D:\programfiles\appfiles is already exists.
did i miss parameter to be passed in the command?
Thanks in advance,
Marwa Ahmad
Re: Reset a sync. folder using AdvancedInstaller.com command
Hello Ahmad,
Please note that you are using an incorrect Reset Synchronized command line statement. You need to point to the folder from your .AIP (project file) and not to the one from the disk in order to resets a synchronized folder from the project. So, you should have something like that:
AdvancedInstaller.com /edit C:\autobuild\programfiles\Installer.aip /ResetSync APPDIR\MySyncFolder
In order to synchronizes a folder from the project with one from the disk you should use a command line like this:
AdvancedInstaller.com /edit C:\autobuild\programfiles\Installer.aip /NewSync APPDIR\MySyncFolder C:\FolderFromDiskToSynchrinize
You can also take a look on the Reset Sync Folders forum thread which debates a similar subject.
Let us know if that helped.
MarwaAhmad
Hello Dan,
Thank you it works! i executed the commands you stated; ResetSync then NewSync.
The commands were:
then
AdvancedInstaller.com /edit C:\autobuild\programfiles\Installer.aip /NewSync APPDIR D:\programfiles\appfiles
best regards,
Marwa Ahmad
You're welcome Ahmad,
