vigyanlabsmys
Command Line help
For command line help, i.e., test.exe /help this will show some options for silent install (I have attached the image). But in that options "/exenoui" this command wont support, it can be done by /q or /quiet So how to remove this help window?
Best Regards,
Re: Command Line help
Please keep in mind that the above command lines options are specific only to our EXE bootstrapper. They don't apply to the embedded MSI file. So, if you'll use the "/exenoui" option, then only the bootstrapper UI dialogs will be hidden (i.e. the pre-installed prerequisites wizard dialogs). In order to suppress the MSI installation dialogs too, you should use the msiexec specific command lines. Please take a look on our "EXE setup" article which should be useful for you.
If you have any question let us know.
vigyanlabsmys
Hi can we suppress that help window?
Best Regards,
I'm afraid the above help window cannot be suppressed.
vigyanlabsmys
If suppress is not possible, Can we edit that help file, if yes can you tell us where to edit that file?
Best Regards,
Unfortunately, this is also not possible.
