jaelys
UninstallPreviousVersions problem
I'm using a custom action "UninstallPreviousVersions" But regardless of whether the existence of the old version, it always has been removed out of MSI's window, and repeated until I cancel the case in order to continue the installation, how to solve?
Re: UninstallPreviousVersions problem
I'm not sure I fully understand your scenario.
Can you please give us more details about your specific scenario and attach some printscreens with the behavior you had encountered?
Please note that with the Uninstall previous versions predefined custom action you can uninstall the older versions of your product, no matter what Installation Type they use (per-user or per-machine).
jaelys
Since http://www.advancedinstaller.com/forums ... =5&t=28372 this issue, I want to remove the old version and remove messages show the progress in enhancing the UI, so I want to try this UninstallPreviousVersions in this way, but it is disappointing, always remove the window out of MSI style, and whether or not there an old version of windows has always jump MSI style recycling, remove the window has jumped out to an infinite
