jaelys
Lose WDAPI921.dll ?
I want to FIX the problem, but out of a lack of Windows DLL, FIX another side note, I do not quite understand whether there is teaching?
Re: Lose WDAPI921.dll ?
I apologize for my delayed reply. We are quite busy at the moment.
You are getting the related validation error because you have enabled the "Auto register file (DLL,OCX,etc) -> Self register native library" option for your "WaninCameraSourceFilter.ax" file. The self registration method of registering components has many drawbacks (like not being able to roll back the changes if something fails later in the install) and it is against Microsoft guidelines. In order to fix this validation error you can proceed like this:
- go to "Files and Folders" page, select the "WaninCameraSourceFilter.ax" file and from context menu choose "Properties..." option
- go to "Registration" tab and enable either the "Extract registration info from native library" or the "Register .NET assembly for COM interoperability" option
