mehrlicht
how to prevent time out exceeded with silent install
Hi..
I built an installation update with silent install.
Sometimes when installing it shows a "timeout exceeded" error.
How can I work around that?
I mean can I configure the installation to force retries or to extend the time limit?
thanks
Re: how to prevent time out exceeded with silent install
You can specify a connection timeout (in seconds) for the browse operation. The default is 60 seconds and the timeout value is stored in the SqlConnectionTimeout property.
So, you can modify the argument of the predefined Set installer property which sets the SqlConnectionTimeout property with the desired value for the timeout value.
Use the attached printscreen as a reference:
