jfha73
Newbie question
Hey guys,
I need to create a new Folder Dialog that contains a file I need to edit, but when I see the available dialogs Folder Dialog is not there, also, I have a file in the [APPDIR] that needs to be edited too after everything else is in place, I can't find a way to do that either.
Can somebody tell me how or where can I do these things in Advanced Installer?
Re: Newbie question
I'm afraid I don't fully understand you scenario. Can you please give us more details about this (maybe exemplify)? If you need to edit a file you can use our "Text File Update" or "Import and Edit XML" support. Also, if you need to browse for a file at install time please take a look on our "Browse for file" how to.
jfha73
Re: Newbie question
I think you understood just right, I'll take a look at text file update and browse for file.
Thanks.
Re: Newbie question
You're welcome.
If you have any question let us know.
jfha73
Re: Newbie question
I found almost everything I need, but I still have not figured out how to tell the text update dialog where the file is (the file I browsed for in the dialog I created)
Any ideas?
Re: Newbie question
In order to achieve this you can just add a reference to the installer property, associated with the edit control (e.g. MY_FILEPATH) from your browse for file dialog, in the "New Text File Update" dialog like this:
  • Append/Create: User selected path = [MY_FILEPATH]
Let us know if this helped, otherwise please give us more details about your scenario.
jfha73
Re: Newbie question
Thanks, that worked, but when I tested it, when it was time to Edit the txt file it said it could not create it because it was already one with the same name, how can I change that, it is not supposed to create a new file, but edit an existing one.
Thanks.
Jorge_.
PS: Advanced Installer rocks, I have tested the leading in the industry and so far the best I have tested.
jfha73
Re: Newbie question
I see what's happening, the Brwose for file is not quite what I need, it would be a combination between Browse for Folder and Edit a file in that folder.
I'm trying browse for a folder, but I'm stuck at step 5, nothing happens when I drag and drop (with Shift pressed) to where the document says.
Any ideas.
jfha73
Re: Newbie question
Can somebody tell me what's wrong with this picture?
Image of Dialog and the Browse button Published Events.
Browse for folder.jpg (41.78 KiB) Viewed 6688 times
When I press Browse it doesn't show me anything.
Thanks.
Re: Newbie question
Can you please try to remove the brackets from the [CONF_DIR] argument and see if the behavior still persist?
So, you should have something like that:
Event:[_BrowseProperty]
Argument: CONF_DIR
Condition: AI_INSTALL
If the behavior still persist, please attach the .AIP(project file) so we can investigate this.
jfha73
Re: Newbie question
I could finally get it to work using a combination of Brow for file, Browse for folder and text file change.
Thanks for your help.
Re: Newbie question
You're welcome,
