Corey
Browse LDAP from installer
Hi All,
Was wondering if there is a way to browse an LDAP server to get a LDAP string from advanced installer? I know i can have an edit box where it can be typed manually, but am looking for something a bit more refined.
Also when moving feature based prerequisites to a new feature, they seem to leave behind some AI registry keys and this can leave you with two features the same or features that contain only those registry settings. How can i move these registry items to the correct features?
Re: Browse LDAP from installer
Unfortunately, we don't have predefined support for this. However, you can try (if possible) to create your own custom action in order to achieve this.
I'm afraid I don't fully understand what you mean. Can you pleas give us a detailed step by step test case which we can follow in order to replicate the behavior? Also, you can try to isolate the behavior in a sample and send it us so we can investigate.
