jaelys
Always the first word of the missing in Action Text
Another representative of the real meaning of SubActionPrefix?
I set Remove correct you, but I did not remove the old version is indeed always appear in this status text
Why there were many duplicate ActionText ?
Text appears difficult to feel the actual installation response
Configuring XXXXX...Done
Remove - actions to configure Windows features....Done
Remove - configured Windows features....Done
Remove - Windows 防火牆操作...Done
Remove - Windows 防火牆組態...Done
Remove - COM+ 套用程式和元件的註冊...Done
Remove - MIME 資訊的註冊...Done
Remove - removed files...Done
Remove - INI 檔案項...Done
Remove - files for removal...Done
Remove - file removal operations....Done
Remove - MIME 資訊...Done
Remove - INI 檔案值...Done
Remove - COM+ 套用程式和元件...Done
Windows 功能...Done
Remove - back configured Windows features....Done
INI 檔案項...Done
MIME 資訊...Done
INI 檔案值...Done
XML 檔案操作...Done
Remove - XML 檔案組態...Done
COM+ 套用程式和元件...Done
Re: Always the first word of the missing in Action Text
The value of the "SubActionPrefix" property will be displayed in the edit control added on "ProgressDlg" dialog only when running an upgrade installation during the "RemoveExistingProducts" standard action when the previous version of your product is uninstalled. If you are encountering a different behavior please give us a detailed step by step test case of your scenario so we can test on our side.
