tomas.maruska
Process of setup does not exit when upgrading
I encountered problem when upgrading. After upgrade, when I click to finish button on last screen, process ServerSetup.exe is not terminated, but it is still alive. Furthermore, it utilizes one CPU core to 100%, seem forever.
I was able to reproduce this on winsows 7 x86, and windows server 2012 x64. I did not try it on more systems.
Please find attached logs from install, upgrade and screenshot from processes tree (which I took after upgrade). Aip file and two setups I already send to your support e-mail for this thread.
Thanks for any advice.
Tomas Maruska
logs.zip
(174.17 KiB) Downloaded 316 times
Re: Process of setup does not exit when upgrading
Hello Tomas,
We apologize for this inconvenience. Indeed, this is an Advanced Installer issue caused by the "LZMA Compression" feature appeared in our last version of Advanced Installer. We are aware of it and a fix will be included in the next version of Advanced Installer which should be out by the end of this month. We will notify you when this will be fixed. Until then, as a workaround, you can enable the Archive installation files into CAB files option from "Media page -> Configuration tab".
tomas.maruska
Thanks for reply. It's OK for me, if new version fix this.
Tomas Maruska
You're welcome Thomas. We'll notify you as soon as our next version will be out.
This was fixed in version 11.3 of Advanced Installer released on June 17th, 2014.
