matt123
Opening the Edit Path Variables dialog
I have an AI project that uses a path variable for the root directory of my binaries. This was created some time ago (in v 10) by using the "convert paths" wizard.
I now need to change this path variable, but I cannot seem to find out how to open the Edit Path variables dialog (described here http://www.advancedinstaller.com/user-g ... ables.html). I am now running v11.1. All I need to do is change the folder pointed at by my existing path variable, and I have been looking through the options in AI for over an hour now - frustrating! What am I missing??
(It would be really useful if the manual pages for certain features could indicate how/where that feature is opened, and what level of AI the feature is available in).
thanks,
Matt
Re: Opening the Edit Path Variables dialog
Hi Matt,
In order to edit the path variables, you can select the Path Variables option from the Application Menu -> Options.
Please take a look on the below image for your reference:
