tomas.maruska
Text artefacts on different DPI
We found problem with text rendering on Radio Button control when set non-standard DPI.
1. Windows 8.1
2. Dpi settings, set custom size - 199%
3. Setup - Classic theme (default)
Find attached screenshots of DPI settings screen and radioboxes with render artefacts.
Regars,
Tomas Maruska
Re: Text artefacts on different DPI
Hello Tomas,
I've tested your scenario but I cannot replicate it. Can you please send me your .AIP(project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
tomas.maruska
I sent you email, with setup package.
Tomas Maruska
Hi Tomas,
Indeed, this seems to be an Advanced Installer issue. It reproduces when the Enhanced User Interface feature is enabled.
A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
This was fixed in version 11.4 of Advanced Installer released on July 30th, 2014.
