ozgekaya
Windows 2012 Server Roles Source Files
I'm trying to add Server Roles while installing my application on Server 2012r2. Event tough I have succeeded with on on another project I'm getting the error specified below. I guess this is because the installer can not find the source Sxs files. THe server I'm installing will not have an internet access and I have already defined an alternate path on Add Server Roles GUI of Windows Server. To check if it's ok I have also installed Telnet client successfully with those sources.
Why am I getting this error? Where is the advanced installer looking for this files? You can find what I'm trying to install on screenshots attached.
Özge
SI (s) (44:74) [04:51:32:840]: Hello, I'm your 32bit Elevated custom action server.
 Found PowerShell path: C:\Windows\system32\WindowsPowerShell\v1.0\powershell.exe
 PowerShell Script Execution Result Code: 4294967295
 PowerShell Script Execution log:
Add-WindowsFeature : The request to add or remove features on the specified
server failed.
Installation of one or more roles, role services, or features failed.
The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required
to restore the feature. For more information on specifying a source location,
see http://go.microsoft.com/fwlink/?LinkId=243077. Error: 0x800f0906
At C:\Users\installuser\AppData\Local\Temp\pss8581.ps1:1 char:172
+ Try                                                  {
    + CategoryInfo          : InvalidOperation: (@{Vhd=; Credent...Name=localh
   ost}:PSObject) , Exception
    + FullyQualifiedErrorId : DISMAPI_Error__Cbs_Download_Failure,Microsoft.Wi
   ndows.ServerManager.Commands.AddWindowsFeatureCommand
Error 4180. There was an error during the Windows features configuration process.
Your original configuration will be restored.
MSI (s) (44!BC) [04:52:52:252]: Product: Application Server COTS -- Error 4180. There was an error during the Windows features configuration process.
CustomAction AI_WinOptFeaturesConfig returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 4:52:52: InstallExecute. Return value 3.
Re: Windows 2012 Server Roles Source Files
Hello Özge,
Most likely, your installation package fails because on Windows Server 2012 R2 does not have the .Net Extensibility 3.5 and since the target machine does not have an internet connection, if fails to download and enable the related windows role.
You can try to add the Windows Server Role without the .Net Extensibility 3.5 option enabled and add a Windows bundle which will enable the .Net Extensibility for the target operating systems as Windows Server 2008 and Windows Server 2008 R2.
Please let me know if that helped, otherwise give me more details about your specific scenario.
