fadysaid
Newbie And Need Help
hi,i'm still new using advanced installer and it's great :)
i need a lil help i used it to create msi silent install for a lil app like winrar it did it great but adding the winrar.exe in the Application Folder then run to install it gets the source stuck still in the programs files in the winrar install directory so i tried to do a file removal but it aint working a screen shot is attached i'd like to know what did i do wrong
thanks in advance ,
Re: Newbie And Need Help
Hi and welcome to Advanced Installer forums,
Since you want to convert an EXE installation package to a MSI installation package, here are the available options:
You can download Advanced Installer and test the trial. During the trial you have access to all the features, without any limits. The setup packages will just include message boxes during the installation, saying they were built with a trial version of Advanced Installer. Other then that, you can change dialog backgrounds, branding, anything you want.
Just make sure you create the project type you need, as the features are limited based on the project type.
oh thanks very much :D but where should I insert the silent switch for example winrar will need a /S command to be auto installed after the package is extracted
and thanks again best support :)
During the Convert EXE(s) to MSI - Wizard, there is one step where you can add the Install Command Lines for your installation package (e.g. /S parameter).
This can be seen at step 4.1 Include an .EXE package from the Convert EXE(s) to MSI article.
yeah well i tried that already to use the /S in the "silent (no UI) but its still shows me the winrar setup popup to click install etc :S
Edit i know now it should be in the basic UI xD
Please note that in the Install Command Lines you can pass optional command lines for launching the prerequisite under different UI environments.
Each command is used by your prerequisite based on the UI level of the main package, i.e. if the main package runs with full UI the command from the "Full UI" field will be used to call the prerequisite, if the main package runs with Basic UI the command from the "Basic UI" field will be used to call the prerequisite, the same for the rest.
This way you can have different command lines for each UI level.
  • Full UI - command line parameters used for an installation with full user interface
  • Basic UI - command line parameters used for an installation which shows only a progress bar
  • Silent (no UI) - command line parameters for an installation with no user interface
Aha! yea i get it thanks very much i've still so much to learn about Advanced Installer :idea: :D i hope you guys won't get annoyed of me :P
thanks a lot
You're welcome,
Take your time, the learning curve is steep at first but once you get the hang of Advanced Installer you'll be set authoring packages with any requirements.
Our user guide has the exact steps but if you encounter any specific blockers, we're here to help.
well thanks a lot i have got a lil prob, i get that when you make MSI from EXE it adds a post install without setting any main feature the question is i tried to do it on Avast Internet Security and worked like a charm :D but the problem is in the license key i tried to use custom action to run it or even add it as post install but the results was all alike running it before the application is fully installed :P which means it doesn't recognize the file to open it with avast so it gives out the open with message any ideas?
thanks again
hello? anyone!? :(
First of all I apologize for my delay reply.
I'm not sure I fully understand your scenario. Can you please give me more details about this (maybe exemplify)?
well first np im sure you had things to do :P so no worries and yea i kinda was writing quick xD well i used Msi from Exe on Avast Internet Security to make a silent install it works great but the problem was that i wanna attach the license key file to run after my avast installation completed but it failed due it launch before the application is fully installed so it won't identify or recognize it xD so here i need some kind of a delay to make sure avast is fully installed or so? :S
In order to achieve that you can create a help setup. This help setup will launch the license file. For this, please take a look on the How do I launch a file after an installation? article with related information for hints and guidance.
You should also disable the Register product with Windows Installer option from the Product Details page for the help setup package.
Add this help setup as a post-install prerequisite, after your existing post install prerequisite. This way, the license will be launched after the installation of your Avast Internet Security prerequisite.
not working :( it's launched too soon before the avast is installed it's like...it starts to extract the avast package then open the license so it leads to the same result i need something to run the license file after the avast is installed completely "its self extract and silent" or more like launch the license via the custom action but based on the avast run "it runs directly after installed"
hellooo? :(
