Nick Price
Installer fails with invalid signature
Hi
I have a multi-lang install, and enabled the digital signing.
when I run the installer, I get an error that the digital signature for disk1.cab is corrupted.
I noticed in the signing windows, it is automatically signing all cab and msi files.
If I remove the signing of all files the setup running normally.
Error image attached
Nick
Error
Error
Re: Installer fails with invalid signature
Hi Nick,
This is currently under investigation. I've received your email with the .AIP(project file). Let's continue the debate over email.
jricci9999
I am getting exactly the same error on one, but not all, of our servers.
I have temporarily worked around this by removing the signature requirement, but I am very concerned some of our customers will get this error where signing the install is not an option.
James
Hello James and welcome to Advanced Installer forums,
The fix for this issue will be available in the next version of Advanced Installer.
Until then, if you need this fix you can send us an email to support at advancedinstaller dot com and we can send you a RC containing this fix.
This has been fixed in version 11.4 of Advanced Installer released on July 30th, 2014.
