kjullion
Transitioning from Wise installer
Our existing clients have our system which will have been installed using Wise installer. I would like, during the initial install of our new AI installer package, to check for the existence of the file called Unwise.exe (the Wise uninstall program) and if it is found then execute it with two parameters; if the current directory is the AppDir (namely, Program Files\Mfr Name\Product Name, then the command line wound be:
unwise.exe /s install.log
but since the current dir could be anything I think I need to do a Custom Action which launches "unwise.exe" as follows:
[APPDIR]unwise.exe /s [APPDIR]install.log
NOTE: Unwise.exe and Install.log file will be found in the same directory.
Trying this out I'm getting an error as follows:
MSI (s) (70:0C) [17:08:20:294]: Note: 1: 1721 2: Uninstall_Previous_Wise_Install 3: 4: C:\Program Files (x86)\Mfr Name\Product Name\Unwise.exe /s C:\Program Files (x86)\Mfr Name\Product Name\Install.log
MSI (s) (70:0C) [17:08:22:147]: Product: Product Name -- Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor. Action: Uninstall_Previous_Wise_Install, location: , command: C:\Program Files (x86)\Mfr Name\Product Name\Unwise.exe /s C:\Program Files (x86)\Mfr Name\Product Name\Install.log
If I do a command line (outside of an AI installation) that includes double-quotes around both these paths then it works, but I can't seem to find the way to make this work within an AI installation.
This cmd line is an example of what does work:
"C:\Program Files (x86)\Mfr Name\Product Name\Unwise.exe" /s "C:\Program Files (x86)\Mfr Name\Product Name\Install.log"
EDIT: I tried every possible combination of including and excluding double-quotes that I could think of, since the path has spaces in it, and none of my tests so far have been succesful.
Can anyone suggest what it is that I might be doing wrong?
Thanks.
Re: Transitioning from Wise installer
Indeed, you should use quotes around your paths, something like this:
"[APPDIR]unwise.exe" /s "[APPDIR]install.log"
However, the custom action can also fail due to lack of permissions. Remember, you are calling an EXE, so the UAC could automatically reject your call and make the custom action fail.
Since running the custom action as deferred with no impersonation is not an option (as it would execute too late), we need to find another option. Can you please tell us how you are running the MSI packages built by AI? Do you run them in full UI mode or deploy the package through Active Directory or SCCM (0or another tool of this kind)?
kjullion
Hi Bogdan,
We intend to release our first AI based installer as an EXE (MSI-inside) and it will be run in UI mode.
Our customers are small companies some likely without an IT staff, so we don't have any plans for Active Directory or SCCM modes.
Thanks.
EDIT: Okay I tried your double-quotes example and I still get this error...
MSI (s) (C0:5C) [16:57:24:982]: Note: 1: 1721 2: Uninstall_Previous_Wise_Install 3: 4: "C:\Program Files (x86)\Mfr Name\ProductName\unwise.exe" /s "C:\Program Files (x86)\Mfr Name\ProductName\install.log"
MSI (s) (C0:5C) [16:57:30:116]: Product: ProductName-- Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor. Action: Uninstall_Previous_Wise_Install, location: , command: "C:\Program Files (x86)\Mfr Name\ProductName\unwise.exe" /s "C:\Program Files (x86)\Mfr Name\ProductName\install.log"
As I said above, the error I suspect appears because of lack of permissions to run the EXE.
You need to schedule your custom action after "Preparing" stage from Install Execute Stage, then set the option "When the system is being modified (deferred)" and "Run under the LocalSystem account with full privileges(no impersonation)".
This should make the custom action have the proper credentials to run and also run just before you install the new files from your package, so the uninstall of the old version should not delete accidentally any of your new files.
kjullion
Hi Bogdan,
Thanks for the pointers. I tried your suggested settings mentioned and I am still not able to affect the un-install. I continue to get the 1721 error.
Here is what the verbose log reports:
MSI (s) (B0:2C) [10:56:01:576]: Note: 1: 1721 2: Uninstall_Previous_Wise_Install 3: 4: "C:\Program Files (x86)\Mfr Name\ProductName\unwise.exe" /s "C:\Program Files (x86)\Mfr Name\ProductName\install.log"
MSI (s) (B0:2C) [10:56:05:679]: Product: Overture NYLife -- Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor. Action: Uninstall_Previous_Wise_Install, location: , command: "C:\Program Files (x86)\Mfr Name\ProductName\unwise.exe" /s "C:\Program Files (x86)\Mfr Name\ProductName\install.log"
And attached is a screen shot of what the AI project settings looks like now.
I apologize for my delayed reply. Can you please please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
kjullion
Hi Daniel,
I have sent the email as you requested.
Thanks.
kjullion
I have one more task related to removing a prior "wise" installation of our application. I discovered that the Unwise (uninstaller) removes a very critical INI file that we need to preserve (it contains user customizations of our app) as we transition to the AI installation.
I have the code working to call "Unwise /s install.log" as a "Execute Custom Action" so that's not a problem, but what I can't seem to figure out yet is how do I make a backup copy of our INI file (immediately) before calling "unwise.exe" so that I can restore that backup file (immediately) after, so that the user customizations are not permanently lost.
What I have tried so far hasn't worked. This is what I tried:
I created a Custom Action called "PM_BackupPMUserINI" which calls a simple BAT file:
copy %1 %2
and in the CA I define the 1st and 2nd params to be the original INI filename and the backup ini filename respectively:
File To Launch:
[#CopyFile.bat]
Command Line:
"[PublicDocumentsFolder][PM_ManufacturerShortName]\[ProductName]\User.ini" "[PublicDocumentsFolder][PM_ManufacturerShortName]\[ProductName]\User.ini.bak"
Then, I tried wrapping the "PM_BackupPMUserINI" CA (as well as the "PM_RestorePMUserINI" CA) around the (known good) "Execute CA" command in the "Install" button's Published Events, like this:
The error that I see when doing this says:
Action start 10:13:37: PM_BackupPMUserINI.
MSI (c) (E8:60) [10:13:37:860]: Note: 1: 1722 2: PM_BackupPMUserINI 3: C:\Users\Cosmos\AppData\Local\Temp\MSI5BCC.tmp 4: /HideWindow "C:\Program Files (x86)\ProMicro\Overture Demo\CopyFile.bat" "C:\Users\Public\Documents\ProMicro\Overture Demo\PM_User.ini" "C:\Users\Public\Documents\ProMicro\Overture Demo\PM_User.ai"
MSI (c) (E8:60) [10:14:05:212]: Product: Overture Demo -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action PM_BackupPMUserINI, location: C:\Users\Cosmos\AppData\Local\Temp\MSI5BCC.tmp, command: /HideWindow "C:\Program Files (x86)\ProMicro\Overture Demo\CopyFile.bat" "C:\Users\Public\Documents\ProMicro\Overture Demo\PM_User.ini" "C:\Users\Public\Documents\ProMicro\Overture Demo\PM_User.ai"
Action ended 10:14:05: PM_BackupPMUserINI. Return value 3.
Info 2896. Executing action PM_BackupPMUserINI failed.
Action ended 10:14:05: WelcomeDlg. Return value 3.
MSI (c) (E8:94) [10:14:05:228]: Doing action: FatalError
Action start 10:14:05: FatalError.
I think that the problem is that the file ("CopyFile.bat") hasn't been added to the the users' hard-drive yet, because it's a new file that I'm including for the first time in my AI installer...how do I solve this?
Thanks.
Hello Kevin,
When added as regular file in "Files and Folders" page the "CopyFile.bat" file will be copied on target machine at install time only after "Install Execution Stage -> Add Resources" actions group (in the deferred execution time). Therefore, if scheduled before this moment your custom action will fail because the "CopyFile.bat" file doesn't exist on target machine. However, in order to achieve what you want you should add the "CopyFile.bat" as a temporary file in "Files and Folders" page.
kjullion
Ok, temporary file sounds like it will do the job.
I added it in the Files & Folders page and AI automatically puts it in the \Windows Volume\Temporary\ folder which I assume is normal; before adding the file I renamed it to "tmpCopyFile.bat" to help me remember the distinction between it and a "normal, installed file".
But when I try to reference this temporary file in one of my Custom Actions (Launch File > Properties > File To Luanch > right-click, select "File..." and in the dialog drill into the \Windows Volume\Temporary\ folder and select the BAT file, when I click OK, the results show that the BAT file has a red-squiggley line below it that says "Invalid identifier."
What am I doing wrong?
Thanks.
Hello Kevin,
The temporary file reference is labeled as an "Invalid Identifier" due to an Advanced Installer limitation. We are aware of it an will try to add an improvement regarding this in a future version of Advanced Installer. Until then, you can just ignore this false labeling of temporary file references.
