RickH
Per-user Application Shortcut Folder problems
We're trying to create an installer "Per-machine if user is administrator, per-user if otherwise".
Application Folder: [AI_UserProgramFiles][Manufacturer]\[ProductName]
Application Shortcut Folder: [ProgramMenuFolder][Manufacturer]\[ProductName]
All-users installation works fine.
But during an installation in a Windows 8, if installer is running in a non-admin user account, we're getting an error that a shortcut is being created under Program Data. Obviously, we need higher privileges in that folder. The instructions at http://www.advancedinstaller.com/user-g ... users.html does not provide enough details to solve this issue.
Could somebody guide us with this problem?
Rick
Re: Per-user Application Shortcut Folder problems
Hello Rick and welcome to Advanced Installer forums,
This may happen if you are trying to install in per-user context. From what I see you are adding an installation resource (e.g. a shortcut) under "Common Application Data" folder. Please keep in mind this is not allowed when you are using the "Per-machine if user is administrator, per-user otherwise" installation type. When this installation type is used you should not add any resource under per-machine locations (e.g. Common Application Data). Please take a look on our "Single Package Authoring" article which contain a list of restrictions which you should take into account.
RickH
Still going around in circles with this issue. I've read the MS article and made some adjustments; per-user package works and per-machine package works. But the dynamic (per-user & per-machine) fails during a limited user installation.
Based on the MS article, the problem seems to be the CommonAppData folder. But how come the "per-user" installation is working fine?
Here's the functionality, I'm trying to achieve:
- single-package; admin user or limited user installs from same package
- AFTER installation, user configures application; this configuration should now be
+ if package was installed with admin rights, config should be SHARED among other users (it contains a unique company wide FTP user/pwd)
+ if package was installed with limited rights, we have no choice but to save the config only for that user
The closest recommendation I found was to save in the CommonFiles folder which to me seems illogical to store config file and logs.
Can you suggest other in-house articles that can guide me better?
Any recommendations would be great.
RickH
I got distracted with my previous post.
I removed all mention of the CommonAppData folder and the original error is back: an error that a shortcut is being created under Program Data.
- per-user build package, we get an error that a shortcut is being created under Program Data
- "Per-machine if user is administrator, per-user if otherwise" build package, installs nicely
Pls advise.
Can you please send us the .AIP (project file) and a verbose log of the failing installation to support at advancedinstaller dot com so we can investigate them?
