davide
Error when updating and creating schedule task
Problem description - Error when updater.exe trigger the update, on creating the scheduled task for the update
Machine: windows vista
User is Administrator on his machine.
The setup is configured to create a task and check every day at 11AM for a new version, the update is trigger but I get the following error message:
"an error was encountered while creating a scheduled task 'updater.job'"
When I launch the installer directly from the generated exe, and not the update the install go perfectly.
Screen Shot 2014-06-17 at 12.41.18.png (34.83 KiB) Viewed 1545 times
Screen Shot 2014-06-17 at 12.41.10.png (33.18 KiB) Viewed 1545 times
Screen Shot 2014-06-17 at 12.32.20.png (59.28 KiB) Viewed 1545 times
Re: Error when updating and creating schedule task
I'm not sure why this happens. Can you please send us the .AIPs (project files) of your target version, upgraded version and of your updates configuration project to support at advancedinstaller dot com so we can investigate them? Also, please send us a verbose log of the updates installation launched by the Updater tool (installed by the target version of your product) and tell us how you are launching the Updater (e.g. using a shortcut, a command line, etc).
