MatsC
Naming a multiple instance at runtime by the bootstrapper
Very nice work in the update 11.2 with Multiple instaces with the possiblity to dynamically generate instances at runtime.
(It´s definitely no easy task what I understand by the Wix-guys)
However, is there any possibility to validate the instancename an user can write in the dialog handled by the bootstrapper?
For now, I have with a resource editor made the current controls in the dialog , there the end user can write an instancename, not visible.
Re: Naming a multiple instance at runtime by the bootstrappe
Thank you for your interest in Advanced Installer and for your positive words.
Currently we don't have support for validating the instance name entered in the bootstrapper dialog at install time. I've added this improvement on our TODO list and maybe it will be available in a future version of Advanced Installer. Thank you for your suggestion.
Could you please give us an example of what kind of validation you need to perform to the custom instance names entered by the user?
Return to “Feature Requests”
