nasowasauch
UI transparency not working in Maintenance Dialogs
when I go to Programs and Features -> Select my already installed package -> Change then the transparency of UI elements doesn't work anymore. Icons, buttons and type group containers are concerned. That looks really ugly. During the first time installation with boot strapper the transparency is working correctly. But as soon as only the msi is used, like in the control panel to uninstall or modify features, then it doesn't. Please see attached picture.
UI screenshot with transparency issues
18-06-2014 14-26-51.png (67.12 KiB) Viewed 3154 times
I'm using Advanced Installer 10.8 build 54215 Enterprise. This problem exists since I'm working with that application (Version 8 upwards). Best regards
Re: UI transparency not working in Maintenance Dialogs
Can you please select the Always(install, uninstall and maintenance) option for the Enhanced User Interface from the “Themes” page >> “Settings” tab and see if the behavior still persist?
If it does, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which replicate this behavior.
Please keep in mind that using any other theme than the "Classic" one require the Enhanced User Interface option to be enabled in the Settings tab from the “Theme” page.
Please note that the “Enhanced User Interface” option require the package as an .EXE (you can have an .EXE with resources inside or an .EXE with resources next to it).
So, you should go in the Media page and make sure that the “Package Type” is an .EXE.
When you run your package, you should run the EXE file for the bootstrapper to handle correctly all the dialogs and controls. Can you run the EXE file and see if the behavior persists?
Let us know if that helped.
nasowasauch
your suggestion to select "Always(install, uninstall and maintenance)" option for the Enhanced User Interface from the “Themes” page >> “Settings” tab worked. Now, the controls are transparent on maintenance dialogs. Thank's for the solution!
23-06-2014 14-40-32.png (12.26 KiB) Viewed 3132 times
I wonder why this option isn't enabled by default?
Best regards
You're welcome,
I'm glad you got this working. We will consider this in a future version of Advanced Installer. Thank you for your suggestion.
