md8070
Build fails due to missing file that should not exist
I am trying to update a package
for some reason, there is a row in the Icon table:
strgexe.exe -> m:\packages\pckgname\Program Files\Icons\strg.ico
this path does not exist and I don't need this icon file, nor the EXE. I click the Delete button on the bar, the row now has a green line going across the whole line.
I tried to build at this point but I get an error that "Resources referred by the project are missing".
How could I delete this row forever?
package created with one of the 9 versions but I'm editing it with version 11.3
thanks much
Re: Build fails due to missing file that should not exist
Can you please make sure if nor the .EXE or the .MSI have a reference to the related .ico file?
In order to reset the reference, you can go in the Configuration Tab from the Media page and use the [ Reset ] to revert to no icon. Please make sure there is no .ico file specified in the Product Details tab from the Product Details page.
You can use the attached image for your reference:
Please met me know if that helped.
md8070
it was the icon on the Product Details page
thanks
You're welcome,
