R.Mueller
Firewall Exception is created in a system group
Hi Advanced Installer Team,
I have a little bit a strange behavior, when creating firewall exceptions. I have one exception, which is created under the group "Windows Remote Management" and I don't know why.
My project looks (in terms of firewall exceptions) like this:
But the result is this:
Any idea, how I can influence the group name at all (because there is no option for that in the UI of AI)? An own group would be nice, instead of just nothing...
Roland
Re: Firewall Exception is created in a system group
Hi Roland,
Most likely there is an already defined firewall exception in the TCP:80 port on the target machine under Windows Remote Management group.
When you install your package, if there is a Firewall rule conflict, the existing rule is backed up, then overwritten by Advanced Installer with your settings. Since Advanced Installer does not allow you to configure a group name, the original remains set.
When you uninstall your package, your defined firewall exception is removed and the original one is restored.
R.Mueller
Hi Dan,
ok. I see this as designed. As seen in my screenshots, the port 80 is opened, which is not so uncommon a server OS.
Thanks for clarifying that.
Will there be a support for naming firewall exception groups in the future?
Roland
You're welcome Roland,
Thank you for your suggestion. I have added this improvement on our TODO list and it will be available in a future version of Advanced Installer.
This improvement has been added in version 11.4 of Advanced Installer released on July 30th, 2014.
