manuel_armas
Cannot upgrade default instance
Able to upgrade other instance but having error trying to upgrade default instance.
Generate instances at installation time is turned on. using AI 11.3
upgrading default instance.png (31.96 KiB) Viewed 4699 times
Manny
Re: Cannot upgrade default instance
Hi Manny,
Indeed, I can reproduce and confirm this issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
This was fixed in version 11.4 of Advanced Installer released on July 30th, 2014.
manuel_armas
thanks... but is your download page updated? im not sure if it will download the 11.4 because the page still displaying the 11.3 version.
manuel_armas
nvm... i tried it.. it download 11.4. thanks.
You're welcome. I'm glad you sorted things out.
