edgsoccer
Help with Install
i am new and need some advice en help. I am trying to have an install, where i have 3 buttons to install 3 different installs. I have a button for the SQL 2014, Database and one for the program files. I want to be able to click on the SQL 2014 button and copy the SQl install folder as temp folder then install it. I have tried this by making SQl 2014 folder into a feature then when i click the button i made an action to install feature then right after that to run the script to install it but with no success. what am i missing? any help would be appreciated.
Re: Help with Install
In order to achieve what you want you can add your installation files into separate features and, then create a custom feature selection dialog. Also, please take a look on our "Creating Suite Installations" tutorial which should be useful for you.
Let us know if this helped, otherwise please give us more details about your scenario (maybe exemplify).
