XiaoFaye
Installer change it's location after return from a Dialog
In my Installer, I added a custom action which is launch attached file, this custom action will be executed when I click the "Next" button of the WelcomeDlg.
The attached file is a .NET exe file I made, following are what it does:
1. get the handle of the installer main window.
2. call the ShowDialog function of a Windows Form and pass the handle in step 1.
3. return "OK" dialog result when closing the Windows Form.
when I was testing the Installer, it works fine. the windows form shows on the screen after I click the "Next" button, and I can't go back to the installer unless I close the windows form, which is exactly what I need.
however, after I close the windows form, the installer change it's location to the left bottom corner, I don't know why this is happening, in my little exe file, it doesn't change anything of the installer.
Works fine here
change it's location after I close the dialog.
Re: Installer change it's location after return from a Dialo
Did you center the window on the center screen? Please take a look on the How do I center a window onscreen in c#? thread which debates this subject.
XiaoFaye
Hi
I found the problem. it turns out that I forgot to release the handle in my little exe file, now, it's working fine.
Cheers,
I'm glad you got this working. If you have other questions, please let us know.
