tomanye
clr20r3 Error
After I Build my .net project to MSI worked on my Pc Nice but it shows The following Error on client PC.
My project has DeveXpress and EF 6.1 Dll
this is what am showing
Re: clr20r3 Error
Can you give us more details about your installation scenario. Maybe iterate a step by step description of the steps you've done in order to replicate the above error. Can you also please tell us if you are getting this error during installation or after installation when trying to launch your installed application?
Also, please make sure that on target machine all of your application dependencies are already installed or they are installed by your installation package. In order to add your application files dependencies to the installation package you can go to "Files and Folders" page and, in turn, select each one of your application file and then use the [Add Dependencies] toolbar button to add their dependencies.
