R.Mueller
Applying Patch fails if previous patch is installed *urgent*
Hi Advanced Installer Team,
I am currently preparing a second patch for our product, which should be patch the product to the latest version. I am using AI 11.1 for both creating the MSIs and creating the patches. I experience now the problem, that the patch can only be installed, if the previous patch is not installed, meaning only directly on the base version of the product.
If the first patch (it was a quickly published hotfix) is already applied, I get the following error message:
Error aplying path to file C:\Config.Msi\PT90A5.tmp. It has probably updated by other means, and can no longer be modified by this patch. For more information contact your patch vendor.
I found this previous topic, which seems to be the same problem, but much older. I tested it on a Windows 2008 R2 server, so not as old as mentioned in the post.
The installation order is the following:
  1. Install Base Image (Version 12.0.2)
  2. Install the Hotfix (Version 12.0.3)
  3. Install the Update 1 Roll-up (Version 12.0.4)
If I skip the second step, I can apply the patch as desired and without problems. After installing the hotfix it doesn't work.
What do I do wrong here with the patch?
Roland
Re: Applying Patch fails if previous patch is installed *urg
Hello Roland,
First of all I apologize for my delayed reply.
In order to have a clear view of your project settings can you please send us the following AIPs:
1. the .aip of your v12.0.2 package
2. the .aip of your v12.0.3 package
3. the .aip of your v12.0.4 package
4. the .aip of your v12.0.3 patch
5. the .aip of your v12.0.4 patch
and a verbose log of your patch failing installation to support at advancedinstaller dot com so we can investigate them?
