enthu.rao
How to remove trial version messagebox
I initially downloaded Advance Installer trial version and prepared setups (done much of work) . Now company has purchased license.I rebuild the setups.
But still it gives warning of trial version.Management does not wish to recreate the setup as setups are tested by testers.Please give me solution to remove the trial version warning.
Re: How to remove trial version messagebox
To remove the trial message you do not need to do anything special because it is automatically removed from the setup if you rebuild it using the licensed version of Advanced Installer.
If after rebuilding your setup the trial message still appears, it may happen if you use a feature that is available only in a higher license type (i.e. Enterprise, Architect) or if you perform an upgrade to a package that was created with Advanced Installer trial.
Can you verify if any of the above applies to you? If not, can you please send us your AIP file and a verbose log of the installation?
enthu.rao
I found trial version is of project type Enterprise and now I have license of professional.The project in which I am trying this change I have not used any Enterprise feature,but still I am unable to change the project type as the first three radio buttons including professional type are disabled.Please let me know how can I changed the project type
Those radio buttons are disabled because a project cannot be downgraded. However, if you are sure that your project does not use any enterprise feature, you can create a copy of it, open it in a text editor and modify the "Modules" attribute from the first row from "enterprise" to "professional", then try to open and rebuild it.
enthu.rao
I tried replacing professional but project hangs during build
Indeed, the workaround I suggested above is not safe and guaranteed and that is why we do not support the downgrade option for a project. In this case, I'm afraid that you need to recreate your project.
