Corey
No IIS Management console for Server 2012/R2
Hi All,
I am having a bit of an issue with installation of IIS on server 2012 and 2012R2. When these are selected as Targeted operating systems in the IIS install the IIS Management console option disapears.
Currently I have had to exclude these OS's in the installer for this to work correctly. Please see the Images attached.
IIS Management Console checked
Re: No IIS Management console for Server 2012/R2
I'm afraid that this is the normal behavior because the "IIS Management Console" feature has different dependencies on "Windows Server 2012" and "Windows Server 2012 R2" than the other versions of Windows.
However, in order to achieve what you want you can use one of the following solutions:
1. Create two "Windows Feature bundles", one that contains all Windows versions except "Windows Server 2012" and "Windows Server 2012 R2" and one that contains only "Windows Server 2012" and "Windows Server 2012 R2" versions
2. Create one "Windows Feature bundle" that contains all non-Server Windows versions, then in the "Windows Server Roles" check "Web Server (IIS)" and when it appears in the "Additional Packages" list from the left, select it and check the "IIS Management Console" feature from the "Additional Role Services" list. In this case the "IIS Management Console" feature will be enabled for all the "Server" Windows versions.
