Jon
Change text of logo field in AI dialogs
I'd like to know if the following is doable.
Most of AI dialogs has a logo field that says "Advanced Installer" - located on the bottom left of the dialogs (see screenshot attached). Is it possible to customize this field and change the text to the name of our company? I managed to do this for the dialogs that are visible from the dialogs navigation tree. However, not all dialogs used by the installer are displayed there, for example, UpgradeDlg, OutOfDiskDlg etc.
I have tried updating the field text under English column from Default Strings tab under Translations. But when I save the project, the English text reverted back to "Advanced Installer".
AI Dialog sample.png (12.46 KiB) Viewed 3074 times
Jon
Re: Change text of logo field in AI dialogs
Hello, You can ignore this question posted earlier. I just realized that these dialogs (or almost all?) are in fact visible from the dialog page - need to scroll & expand in some cases. This gives me the ability to update the text of the logo field.
Learning something new everyday about AI! Thank you for your time!
Indeed, all that dialogs used by your package are displayed in the "Dialogs" page and you can modify them all there.
