matt.luthi@gmail.com
Upgrade installer detects windows explorer taskmgr
When I run my installer as a major upgrade, it detects windows explorer and taskmgr as dependent processes. Why is this happening. It causes the installer to reboot at the end which is what I am trying to avoid.
Matt
Re: Upgrade installer detects windows explorer taskmgr
Hi Matt,
I'm not sure why this happens, but maybe your application tries to modify some resources related to those processes (DLLs, assemblies, etc.).
If you mean that it asks to restart the machine at the end of the installation, but you don't want it, you can go in the "Install Parameters" page and select the "Suppress all Reboots and Reboot prompts" option from the "Reboot Behavior" combobox.
