prashanth.a
unable to bind certificate to https
Im unable to add certificate to https binding in IIS, Im am getting an error while installing
kindly guide me further
Also im unable to delete the default website, we need to delete it because our application use default ports 80 and 443 but if default website is not deleted we cannot start the website.
IIS configuration in Advanced Installer
error 2.JPG (123.68 KiB) Viewed 6154 times
Error while installing
error 1.JPG (31.25 KiB) Viewed 6154 times
Re: unable to bind certificate to https
Can you please try to use the latest version of Advanced Installer and see if the behavior still persist?
Please note that there is no need to delete the Default Web Site. During installation, if the Default Web Site is using the same port as the Web Site from the installation package and the Default Web Site is ON then we stop it first and then turn on your Web Sites after the installation process.
prashanth.a
Hi Dan,
Tried all the possible ways in Advanced Installer but it it fails have also tried in older versions :cry:
I'm using Advanced Installer 11.3 Enterprise.
and regarding default website it worked thank you dan.
Please help me with binding the certificate it is very important for my installer to be total automated.
In order to get more details about what happens can you download the following debug DLL, replace the original one from the install folder of Advanced Installer 11.3 (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 11.3\custact\x86) on your machine and rebuild the package?
Just replace the original iis.dll from the install folder of Advanced Installer with this one, then restart the application and rebuild the package. This DLL should create a debug log (at install time) on the root of the OS partition (e.g. C:\AI_IIS.log), which can give us more details about the problem. So, can you send us the AI_IIS.log file, to support at advancedinstaller dot com, after you will build and test your installation package using the debug iis.dll?
prashanth.a
Dear Dan,
I enabled debug mode will this log file be helpful.
installerlog.rar
Log file is compressed
(292.4 KiB) Downloaded 371 times
I'm afraid the Windows Installer log is not the most helpful in this case.
We need the log file created by the debug version of the iis.dll. Please send us the related log.
prashanth.a
Dear Dan,
have sent an email as requested...
Please find the attached file below too..
AI_IIS.log
(201.73 KiB) Downloaded 321 times
Hi Prashanth,
As far as I can see from the log, the installation fails with the A specified logon session does not exist. It may already have been terminated error message. Googling it, there were other users that complain about this.
Also, your certificate is already in the System Store. So, can you please remove it first and then try to run your installation package once again and see if the behavior still persist?
prashanth.a
Hi Dan,
I tried installing in new system its the same error for the certificate :( im reaching my deadline for the project as this is the important part of it.
