Cubiboy
Install XAMPP and PHP Code
I hope, that I'm in the right forum (i'm new).
So my question:
I have coded a webapp in PHP and tested it in XAMPP. Now i want, that the users of the App can Install this Simple with the Installer, so they don't have to do anything manuel.
I have added the XAMPP.exe Package in the Feature-based Folder and the Application Folder edit to "C:\xampp".
How can I copy the PHP files to the htdocs folder of xampp? And how can I overwrite the Database files of XAMPP?
Sorry for my bad english (I'm german).
Thank you for you're answers.
Re: Install XAMPP and PHP Code
Indeed, the above configurations are correct. In this case the "XAMPP.exe" package is installed to its own location (i.e. C:\xampp) and the files from your project will be copied to the "Application Folder" path (in your case C:\xampp folder).
In the Files and Folders page of your project create two new regular folders under "Application Folder" called "htdocs" and "database".
The content of these two folders can be overridden by your package at run-time if you use the option displayed in the screenshot below, therefore the files from your package will be copied to those folders and will replace the original files.
Cubiboy
Hello Eusebiu,
Thank you very detailed tutorial and youre fast answer.
I try it and if it doesn't work, i post again in this Thread.
Cubiboy
You're welcome. Glad to help.
Just let us know if any problem appears.
ahmed.gad_it
How to do these steps for Linux 64 and MAC OS?
Thanks!
I am afraid we do not have any web app support for Linux 64 and MAC OS.
