Azef123
Get value TextBox Dialog with PowerShell Script
Dialog with text box
First, I am new and i try the software.
I am in "Architect" mode. I add a dialiog sequence with "Edit Box" and i would like get value enter by user in Powershell script.
How in the custom action (PowerShell script) can I get the text value ?
PowerShell script to get value text box
Re: Get value TextBox Dialog with PowerShell Script
A custom action written in PowerShell can access Windows Installer properties with the help of _msiPropOutFile predefined temporary file:
001: param($_msiPropOutFile)
Please take a look on the Run Windows PowerShell Script article for more details.
Let us know if that helped.
Azef123
I found how to get value properties but in .vbs :|
1. In Dialogs menu, add Edit Box
2. Check name "Property Name" in right menu "Properties". (For me Property Name=EDIT_2_PROP)
3. In Custom Actions add "Execute inline script code"
4. Use script Type vbs
5.
Dim text_box
text_box = Session.Property("EDIT_2_PROP")
MsgBox("Text enter by user: "+text_box)
6. Execute in Install only condition.
So, to get access properties use command Session.Property("YOUR_NAME_PROPERTIES")
Now, i try to do the same but in PowerShell. What is the equivalent command in PowerShell of Session.Property("YOUR_NAME_PROPERTIES") ?
I read the article and i continue to look for a solution.
$msiProps = @{ "YOURPROP1" = [i]Session.Property("EDIT_2_PROP")[/i]; "YOURPROP2" = "abcd" }
$msiProps.Keys | % { "$_ : " + $msiProps.Item($_) } >> C:\testlog.txt
This software it's very good and the graphic interface "user friendly".
I apologize I missunerstood your scenario.
It seems that power shell script does not have predefined functions to retrieve the value of a Windows Installer property. However, using our Run Windows PowerShell Script custom action, in order to achieve what you want you can access the edit box associated property (e.g. EDIT_BOX_PROP) within your PowerShell custom action like this:
1. in the "Script Parameters" field of your "Run Windows PowerShell Script" custom action add the following parameter:
-myPropVal [EDIT_BOX_PROP]
2. within your PowerShell script code, declare the "myPropVal" parameter in the parameters section of your script like this:
Param ($myPropVal)
3. after declaring the "myPropVal" parameter in the parameters section of your script body, you can access its value anywhere inside your script
