Shreyans26
Know the Download Details of EXE.
I am using the following code to silent download my updates for application.
process = Process.Start(Constant.UPDATER_FILE_NAME, " /silentall -justdownload");
But the problem is i want to know the percentage of the data that is downloading silently in taskbar. So that user can know something is getting downloaded and ready to update.
What can i get the download information of my updater EXE.
Re: Know the Download Details of EXE.
Currently, I'm afraid we don't have Updater support to send to your application a silent download progress. However, we already have this improvement on our TODO list and hopefully will be available in a future version of Advanced Installer. We will notify you as soon as this improvement will be available.
Shreyans26
Thanks for the reply.
Okay,we would be waiting for the update with above scenario. :)
You're welcome.
The command line switches support for the Updater which allows you to implement this scenario have been added starting with the 11.5 version of Advanced Installer released on September 25th, 2014.
You can use the following command line switches for the updater:
/silentall -nofreqcheck -reducedgui
