El-ahrairah
Property Based Synchronized Folder / AI_AIP_FOLDER
I would like to use the AI_AIP_FOLDER property in the following location, but I am unable to determine how:
Resources >> Files and Folders >> Application Folder >> Synchronize >> Source Folder (see attached screenshot)
An example would be to set the "Source Folder" string to the following:
[AI_AIP_FOLDER]\SetupSource
- or -
[AI_AIP_FOLDER]\[ProductVersion]\SetupSource
I have been unable to find a way to do this via searching the forums or documentation, so I apologize if I have overlooked the answer.
(edit 1)
This would be useful to us when creating a re-usable project template.
(edit 2)
Changed AI_APP_FOLDER to AI_AIP_FOLDER
Advanced Installer Details:
v11.4
Project Type = Enterprise
Re: Property Based Synchronized Folder / AI_AIP_FOLDER
Unfortunately, we don't have support for your requirements. I've added this improvement in our TODO list and maybe it will be available in a future version of Advanced Installer. Thank you for your suggestion. However, since your is the only request implementing it has a low priority for the moment.
In the meantime the only workaround would be to manually set again the synchronized folder location after creating a new project by using your project template. Thank you for your understanding.
