Paul954
User defined install folder
I am trying to install my web app in a folder that is determined during the install.
A normal install path would be C:\inetpub\wwwroot\webappname.
I am using the BrowseIIS dialog and would like the webappname to be determined by the property name of the Virtual Directory edit box. I have set this property name to be MY_WEBAPP.
If, during the install, I input webappnameA into the Virtual Directory edit box, I would like the web app to be installed into C:\inetpub\wwwroot\webappnameA.
I have gone through several of the Help and How To's without any success.
Re: User defined install folder
In order to achieve what you want you can use a custom installer property (e.g. MY_WEBAPP_FOLDER) to create a property-based folder under which will be installed your web application. Here are the steps to proceed:
1. go to "Install Parameters" page and add a new installer property like this:
  • Name: MY_WEBAPP_FOLDER
    Value: Your Value
2. go to "Files and Folders" page and create a property-based folder using the above property
3. go to "IIS" page, select your web application entry and in the "Folder" field from "Basic Application Settings" tab set the "MY_WEBAPP_FOLDER" directory
4. go to "Custom actions" page and add a "Set installer property" custom action with sequence, scheduled after "Install Execution Stage -> Searches" actions group like this:
  • Property: MY_WEBAPP_FOLDER
    Value: [IIsWWWRootFolder][MY_WEBAPP]
5. select the above custom action and , while keeping [SHIFT] key press drag and drop it under "Wizard Dialogs Stage -> Searches" actions group (in this way the custom action will be shared between the two installation sequence.)
6. rebuild and test again the scenario
Let us know if this helped.
Paul954
I can not drag and drop the Set Property Action. It doesn't do anything when I try.
Image 2.png (24.12 KiB) Viewed 3595 times
Paul954
I have figured it out.
Thank you for the info. I have it working now
You're welcome. I'm glad you sorted things out.
