Paul954
ODBC Connect: timeout exceeded
I am using the Test ODBC Connection to test the sql connection during the install.
As I am not using ODBC, Is there any way to edit the error popup to change ODBC to SQL?
Re: ODBC Connect: timeout exceeded
I'm afraid I don't fully understand what you mean. Can you please give us more details (maybe exemplify) about what you are trying to achieve?
Paul954
This is the error message popup I get if the sql connection test fails. I would like to have the error message say SQL Connect:timeout exceeded instead of ODBC Connect:timeout exceeded.
ODBC sql connection error.png (6.22 KiB) Viewed 3138 times
I'm afraid this is not possible. Please keep in mind that the related ODBC error messages are spawned by the ODBC driver you are using in the SQL connection string (i.e. specified as value for "Driver" parameter of the SQL connection string). They are not error messages spawned directly by the Advanced Installer.
If you want you can remove the ODBC error messages by setting the SqlSuppressSpawnMsgBox property to 1.
