Antarctica
Write access for all authenticated users
I deploy a Web Application using AI 11.3 and I want to grant all authenticated users write access to a certain directory.
So I did in AI:
-> Open "Files and Folders"
-> Rightclick on folder
-> Select "Properties"
-> Tab "Permissions"
-> "New"...
-> Username: "Authentifizierte Nutzer"
-> checked the "modify" checkbox
-> clicked OK.
Afterwards, Installation went smoothly in our test environment.
Now we got feedback from a customer which uses locale EN in Active Directory.
The error message (compare attached screenshot) says sth. like "An error occurred while applying security settings. Authenticated users is no valid user or group. ..."
I think that this is caused by localization of the group name, which is "Authenticated Users". Is there a way to set the permissions for standard users/groups to work with every localization? I would hate to have to make a special turkish setup because one customer uses a turkish AD...
mihai.petcu
Re: Write access for all authenticated users
Authenticated users group is not localized in Advanced Installer. All localized groups are listed in How do I localize user or group accounts? user guide article.
If you have a choice I recommend you go with one of the localized groups otherwise you'll have to create a custom action (e.g. which uses XCACLS or ICACLS) to set the permissions.
