kanchanc
Repackager crashes out while launching
Hi, I downloaded / installed Advanced Repackager 11.4.1 for evaluation purpose. While launching Advanced Repackager, it is crashing with the following error -
[SEH_AV_READ_NULLPTR] ACCESS_VIOLATION (0xc0000005) at address [0x001c029d]
Advanced Repackager (x86) 11.4.1 build 58484
*** Stack Trace (x86) ***
[0x001c029d] -----
[0x00120000] MODULE_BASE_ADDRESS
Please help so that I can proceed further.
Best Regards...
Repackager Launch Error
Re: Repackager crashes out while launching
I'm not sure why this happens. Can you please offer us more details about when this error appears? For example, you can try to give us a detailed step by step test case which you are performing when this error occurs. Is this happening when you are launching the Repackager using the "Repackage Installation" project template or when you manually launch the Repackager tool (e.g. from a command prompt window)? It is crashing at the very beginning when the Repackager starts or later during another Repackage Installation step?
Also, please tell us if this error is randomly or if it is replicating all the time. Any additional info you can offer us would be very useful.
kanchanc
Thanks for your response.
The particular error is shown at every launch of "Advanced Repackager" shortcut installed in "Start Menu\Programs\Advanced Installer 11.4.1" folder. So far, I am never been able to see the repackager screen to be honest. Is there any log file created by "Advanced Installer" application that I can share with you? While I was writing, I just re-launched to verify that the error still persists. I've already restarted laptop couple of times just to be sure of.
Best Regards...
I've tested the scenario on multiple clean machines, but I cannot replicate the behavior. Can you please tell us what is your machine software configuration (Windows version, SP level, OS language)? Also, can you please try to uninstall and, then reinstall again the Advanced Installer application and see if the problem still persists?
Also, please specify if the error occurs when you are trying to launch the Updater using the following method:
1. open AI application
2. from "Start" page go to "Import -> Repackage Installation" project type and click on [Create Project] button
