manuel_armas
How the multiple instance works with side by side install
Hi ,
How the multiple instance works when I have also the side by side installs of different product versions allowed?
9-2-2014 11-02-17 PM.png (4.14 KiB) Viewed 2053 times
Manny
Re: How the multiple instance works with side by side instal
Hi Manny,
Please keep in mind that the "Multiple Instances" feature is not quiet compatible with the "Side by side" feature and it is not recommended to use them both. Using only one of them (depending on the intended scenario) should be enough. A similar problem was discussed on the Multiple Instances - Cannot Upgrade Instances thread.
