ddl
User name + Domain + Password PROPERTIES
I just bought the PRO version.
I added the LogonInformationDlg and I want to run custom action [ps1 script] which set sched Task with that user.
What is the PROPERTIES of the user \ domain \ password ?
ddl
Re: User name + Domain + Password PROPERTIES
The name of those properties are: USER_NAME, DOMAIN_NAME and USER_PASSWORD.
For the future, when you need information about some "Enterprise" or "Architect" features, you can create some projects of those types on your machine and get the necessary information. In this case you will lose time waiting for our reply.
ddl
I want to pass this PROPERTIES to powershell script.
From "Add custom action" > I select "Run Windows Powershell Script".
In "Script Parameters" I write USER_NAME
Now, how this PROPERTY can be inserted to Powershell var ?
I tried $args[0] - doesn't work.
I read 10 times the section "Run Windows PowerShell Script" - can't understand [why not add little sample ?]
ddl
You can take a look on the Get value TextBox Dialog with PowerShell Script thread which debates a similar problem.
We will update the help and add some samples in a future version of Advanced Installer. Thank you for your suggestion.
