shetty_rohan
Minimimized final screen
QA has found one problem, it is very easy to reproduce in Windows 8.1.
Reproduction steps:
1) Extract the sample.zip(Will mail you the setup)
2) Open the setup.aip from sample\Sample\client\client\Setup\DesktopControl\UCSoftphone
3) Build the Teles_build
4) Run the setup
5) Continue pressing next or relevant buttons till 'Install'
6) After pressing Install minimize the dialog box
7) After sometime(i.e once the installation completes), click on taskbar icon to maximize the dialog box.
8) Now, when the dialog opens, it appears to be minimized, and maximize button is disabled. So basically user can not maximize this screen at all. He only has an option to close the dialog.
Can you please help me with this problem?
Rohan
Re: Minimimized final screen
Hi Rohan,
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention. Unfortunately we have no workaround for it yet. Sorry for the inconvenience.
shetty_rohan
Thanks, will wait for the fix. Do let us know once this is fixed.
You're welcome Rohan. We will reply on this thread when the fix is available.
This was fixed in version 11.6 of Advanced Installer released on October 23rd, 2014.
shetty_rohan
You're welcome,
