Shreyans26
Forcefully Installing The Updates
I have created the windows application, we send updates to user who have installed the application.
And the tedious thing is he has to go through all the process first download update and install the update.
I don't want the user to go through the process.
i just want the application to silently update and install the update file forcefully and restart the exe.
Can this be done?If yes can i get the steps to do that?
Re: Forcefully Installing The Updates
In order to achieve what you want, you can take a look on the How to handle updates without elevation article.
To restart the .exe you can go in the "Update Configuration" project, "Auto Close Application" tab, then add the path to your application and set the "Restart Always" flag for it.
Shreyans26
Thanks for the reply,
I tried to have that flag=advertise i.e so that install without elevation and also the restart flag.
Even after that i tried to update, it showed with UI setup with next next option to install.
please find the aip and the config file i m using,
LocalSetup.aip
this is the setup aip i am using
(140.17 KiB) Downloaded 315 times
updates.txt
here is the configuration file
(521 Bytes) Downloaded 235 times
Please keep in mind that one of the most important steps mentioned in the How to handle updates without elevation article is to enable the "Install support service" option from the Updater page. This option was not enabled in the project that you sent.
Can you enable it and see if it works?
Shreyans26
Yes, thanks for the reply and it helped.
Ya i enabled it and now its working but the problem is I get the Dialog that shows the downloading of updates and then the installing is done without UI as i wanted.
Only problem is i get the dialog which shows the percentage of download and display feature,bug etc which i don't want to show the user.
This is the dialog that shows up
updates screen.png (41.81 KiB) Viewed 5439 times
For that dialog to also not be displayed, you can go in the "Updater" page of your project and check the "Silently check for updates and automatically install" option.
Shreyans26
Hey,
Thanks for the reply..
i have enabled the option still it shows up..
But one more issue i noticed, till yesterday i was usingg advanced installer version 10, today i updated the advanced installer to 11.4
Now the previous the commnadLine = /exenoui /qn doesnot work, it says updation failed.
please find the attached update file
updates.txt
this is the latest config file
(519 Bytes) Downloaded 236 times
LocalSetup.aip
This is the setup file
(141.68 KiB) Downloaded 272 times
Shreyans26
Thanks for the help, :D :lol:
I have solved it, actually issue was with administrator rights :oops: .
As i was using command line option in the config file.
Shreyans26
yes suree...And Thanks for help.
