Jaradat
Error while excuting Batch file
When executing Batch file, on windows 8 64-bit it failed with an error
Error
Error
Re: Error while excuting Batch file
I'm not sure why you encounter that error. Do you launch that batch file from a package created with Advanced Installer? If so, can you check the "Use 64-Launcher" option and see if it works?
